Scott Goldsmith
- Sep 19, 2002
Does anyone know what might be causing this problem. When I am watching a DVD or TV, sometimes during a certain angle or schene, the picture will get all distorted at the very top part only, kind of twist the image to the left, but the bottom half is normal, and when the schene changes it goes away and it's all fine, if that same view of the schene comes back it will distort again. For example, during the Matrix Reloaded, when Neo is talking with the Architect towards the end and they show them both from the side, the top part of the TV gets messed up and distorted like I describe, and when the schene changes it goes away, then it comes back to the same view and it comes back. Any idea what the hell this is??
I am using the new Monster Cable THX component cables, hooked up correctly too. Do you think it's heat that is causing it. It will do it more when I have been watching it for a while.
Thanks in advance.
Thanks in advance.
