Jaimin
- Aug 4, 2002
Well I have been browsing around and doing my research and I have come to a couple choices for my 5.1 setup. I have a really small room, its about 12x10 and I am pretty much set on getting a Pioneer vsx-d811s (unless someone can really convince me otherwise). For my speaker setup I have narrowed it down to about two choices, but if anyone has suggestions in the same price range I will definetly look them up. The first setup is four jbl s26's all around and an s-center which is pretty popular around here. The other is an axiom setup with four m2i's and a vp100 center. Both those setups are very similar in price however I can only go on their performance based on numbers and opinions. I am gonna try to demo the jbl's if I can find somewhere in the Northern Chicago suburbs to demo them (anyone know of any places?), and it seems like the axioms will be close to impossible to demo, so those are some what of a gamble, although those speakers are highly regarded around here as well. Basically I want your guys opinions on these choices because its gonna be hard for me to demo these. I am leaning more towards axiom because they are more efficient speakers, however the jbl's supposedly have a wider frequency response which might help since I am not going to have loads of money to spend on a subwoofer. The jbl's on paper go down to 48hz while the axioms go down to 70hz at +/- 3 dB's. The axioms have a higher crossover, I don't know what that indicates, hopefully someone can explain. Both have similar max power ratings, 150 for the jbl's and 175 for the axioms, but that shouldn't matter to much because I have a small room. Also the axioms have a smaller woofer at 5.25in versus 6in for the jbl. They both have the same size tweeter and both systems are timbre matched. I have read that the jbl center is superior to the vp100 but that was just someones opinion. Sorry for typing so much but I wanted to cover all the bases. Hopefully someone can make more sense out of all this technical information than I could, I mean I understand the numbers, but I don't truly know what it will produce in the real world. Oh yeah, and as of now I can only spend about $250 on a sub, so I was leaning towards the audiosource sw15, but please let me know of anything else that would work. I was also looking into an acoustic research PR1212. I am using this system equally for HT and music. Hopefully those of you with greater technical knowledge and those of you that have used either or both of these speakers can give me your opinions. Thanks in advance for whatever you have to contribute.
Jaimin
Jaimin
