Jon_H
- Feb 22, 2000
I just recently recieved my Panasonic 47" HDTV and its great. Last night I decided to start calibrating it with Avia. I just decided to run the basic picture configs last night. Wen I got to the sharpness test I tried setting the sharpness on the set and chaging the setting from 0 to the highest made no difference to the graph on the avia disc for sharpness. Am I doing something wrong or am I just blind or does sharpness not come into play on this set. The source is a panny Progressive scan dvdplayer.
Also when I adjust the Picture with the avia disc (the one with the gray steps and the 2 black bars going back and for underneath)i can turn it all the way up and the top white block doesnt bloom (wich I dont think it would on a RPTV) and nothing happens to the moving bars at the bottom. So how do I set this, I cant see any point where I should stop moving the setting up, I am confused here, so i just put it in the middle.
Also, anyone know if there are separate R/G/B adjustmensts in the service menu? My red is relly high and so is my green, not as high as the red though and I have my blue set fine.
Anyone know any good sites that would explain how to focus the lenses also, my blue is pretty out of focus.
Thanks, any help would be appreciated
