Art Miller
- Sep 30, 2001
Quick question: If I'm using Large speaker settings in DD/DTS does ALL of the Low frequency info go to the main R/L speakers if I'm NOT using a sub?
The reason I ask is that I am using a biamp MTM/Sub stereo speaker setup, and I'd prefer to leave it as it is, with the separate electronic crossover splitting the signals between the sub and MTM's. I would consider changing this arrangement if I'm missing out on any bass info that is not going to the subs via the "Large" setting.
Pre/precessor is a Sherwood AVP9080R, although I'm guessing that the specs are a Dolby function and should be implemented the same way in all approved processors.
