Help with JBL PB12
Discussion in 'Speakers & Subwoofers' started by Brad E, Feb 5, 2004.
  1. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
    There are two green lights that light up when the sub is powered on.
    But yesterday I noticed that the lights were red.
    Today they are back to green.
    Does anybody know why it's doing this? I was thinking maybe it had something to do with a setting in the reciever, but I couldn't replicate it.
    There is no info in the manual or on the JBL website, so any info will be helpful.
    Brad
  2. John_Bilbrey
    John_Bilbrey Stunt Coordinator
    Jan 16, 2002
    206
    110
    Green means the amp is on, red means it is in standby. If your receiver "master volume" is set low, it may not send enough signal to trigger the "remote on" of the sub. Try adjusting volumes. I also notice a difference in source material. DVDs will kick the sub on at lower volume settings whereas satellite often needs a little more volume to get her cranking. I can even notice a difference between stations on satellite.
  3. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
    Thank you sir. I was beginning to think I was seeing things or going crazy or both.
