help with inwall placement please!
Discussion in 'Archived Threads 2001-2004' started by MichaelDW, Mar 13, 2002.
  1. MichaelDW
    MichaelDW Stunt Coordinator
    Dec 2, 2001
    60
    I have a room that is 1220 the left wall is 8' from sweet spot and the right wall is 5' from sweet spot I dont know if I should put speakers there or 3' behind me on rear wall. what do you suggest? my other delima is put them in both spots to have a 7/1 system. I was told the rear wall was to close for that and I could not tell where the sounds were coming from. just for more info I only plan on using dipole if I GO 7/1. thanks for all yall's previous help I love this web page its great
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    If budget allows...I would go with the 7 channel setup. This will give you much more flexibility down the road. Using dipoles to the sides is fine, but I would stay with direct rads or bipoles in the rear.
    TV
