Help with finding a reciever for first HT
Discussion in 'Archived Threads 2001-2004' started by Michael Wilcox, Jan 27, 2002.
  1. Michael Wilcox
    Michael Wilcox Auditioning
    Dec 28, 2001
    10
    Hi, I'm currently putting together my first home theater and am not sure which receiver to go with. The receiver will be powering Definitive Tech. BP10s in the front, a CLR 1000 and 2 BP2Xs in the rear. The room is relatively small, 15 X 10. The system will be used mainly for DVDs and digital cable. I'd like to find a receiver with Pro Logic II as I watch a lot of 2 channel sources from the cable. I'm looking to spend $400-600. Thanks in advance.
    Mike
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    For a first HT, with Pro-Logic 2, i would recommend the Kenwood line, either the 509 or 510 would be good for your situation. Both have DPL2 decoding, as well as Circle Surround 5.1 and the basic DD/DTS. Both have IR/RF backlit remotes, and the VR510 is THX Select certified.
    Kenwood VR-510
    Kenwood VR-509
    Both are well within your price range in MSRP.
    (509 is $400-$500, 510 is $600-$700 MSRP)
  3. Kyle_Y
    Kyle_Y Stunt Coordinator
    Nov 9, 2001
    238
    I would say to try and do with a Denon or Onkyo, that is a good set of speakers which deserve better power than a $400 receiver, try to go for a brae minimum of $600 and if you can $700. Denon 1802 or 2802 have good power and the Onkyo 696 will give you good warm sound. I feel that Yamaha also has some good offerings, but I would get an Onkyo or Denon.
  4. Albert M
    Albert M Stunt Coordinator
    Jun 19, 2001
    222
    I would get the new Kenwood VR-6070 this spring. The VR-6070 also features THX Select and DTS-ES audio certification. It will be equipped also with DD, DTS, DPL2, DD Surround EX and the new Circle Surround 2. It will have 8 channel preouts. Retail is $600.
