Denis K
- Dec 8, 2000
Hey folks,
Well I've pretty much decided on the "5" part of a new 5.1 setup. I'm going with and Ascend Acoustics setup. Now for the ".1". As part of Ascend's HT package, I can get a HSU VTF-2 for what works out to be $350 (vs. $499 from HSU). My other option is to go with an Adire Rava ($399). Even though the HSU retails for $100 more, I can get it for $50 less than the cheaper Rava. But considering that I plan to use the sub for a long time, and that performance is the most important factor, I'm not going to sweat $50 either way.
Since both HSU and Adire are i-companies I can't listen to either, let alone both subs to compare them. I have read everything I can find on HTF and AR, but would really appreciate thoughts and recommendations from you folks on which to go with. Or at least additional factors to consider.
Room size: 16.5 x 16.5 with vaulted ceiling max 10ft. (approx. 2380 cu. ft.). This is an enclosed room that does open into others areas.
Use: 65% HT, 35% music
Thanks heaps in advance!
