Daniel T
- Jan 26, 2002
My Laserdisc player has finally gone caput, so I need to break down and buy a DVD player. I have looked at both the Panasonic RP56 and the Toshiba 3750 or 4700. After reading many other post I was convinced to go with the Panasonic, but then I read other post that convinced me to go with the Toshiba. It is hard to choose which one would be best because there are many people who have said good and bad things about both. The DVD player will be hooked up to a 36" Conventional Panasonic TV and H/K AVR55 with only Dolby Digital. I plan by the end of the year to dive into seperates to drive my system, but do not plan to go with HDTV for a couple more years unless I win the lottery. I would appreciate as much help as possible. I would even consider a JVC or Pioneer if they are highly recommended. Thanks.
Daniel T.
Daniel T.
