Richard_M
- Feb 8, 2001
I have just installed my new 3802 and would like some help if possible.
1. There is a faint hum coming from all speakers all the time, You can notice it during quite passages or changing dvd's etc. BTW I have just replaced my Yamaha 795, which did not make any noise at all. And yes it also does it with no external components plugged in i.e. earth loop. Now do they all have this noise or have I got a dud?.
2. What level do I put the speakers at i.e. most are set around zero, is it advisable to run them this way or up them to say +10, so the volume control only gets to maybe +4. This I find confusing why the volume reads from -70 to +15
3. How important is the matching up of the rear speakers, I currently have B&W 602's for the rears so do I buy more, or say leave these as the rear centre's and buy some reasonable quality flush ceiling mounts or small wall mounts etc.
Richard
Richard
