Steven_ R
- Jul 31, 2000
1. I continue to have problems connecting my new Comcast HD Digital Cable Box. The component video outputs are plugged into the component inputs on video 5 of my Sony 61HS10. I have plugged the composite video output into Video 4. This setup keeps me from having to change the cable box menu from 1080i to 480i when I want to watch a non-HD program, plus the non-HD material looks much better through the composite cable into Video 4 than it does using the component cables into Video 5. However, I just discovered that the digital cable menu and guides do not appear through the composite output, even though the program is displayed fine. That is, if I turn on the digital cable, and activate the menu, I get both the program and the menu on Video 5 (via the component cables), but on Video 4, I only see the program and not the menu or program guide. It appears as if the cable box only has the ability to send the menu/guide out through the component outputs or perhaps the component outputs override the output through the composite output. How do other members of this board handle this type of issue with either satellite or other cable systems? I looked on the cable box menu to see if there is a setting I can change, but no luck. I have yet to try the S-Video output from the cable box, and maybe that will display the menu/guide at the same time as the component output.
2. Also, and closely related, what about the audio output? For now, I'm only using an optical cable output from the cable box, but it seems like the sound isn't always in sync with the picture on non-HD material. I tried connecting to the receiver with the RCA type audio plugs, but that does not bypass the digital sound output of the HD box. Ideally, I'd like to be switch between HD sound and video and non-HD sound and video as easily as possible.
Any thoughts?
Thanks.
Steve
Any thoughts?
Thanks.
Steve
