Clark Bradley
- May 2, 2004
I just got this from deepdiscountdvd.com. Unfortunately, it is not anamorphic. My TV is 16:9 aspect ratio and set to Wide Screen. The DVD player is set to show the movie in 16:9. The DVD is a widescreen version. Here is the odd part:
On playing the movie, the menu comes up normally. Takes up the whole TV screen. When I play the movie, it gets squished to the middle (characters are wider than they should appear) of the TV with large (unusually large) black bars at the top and bottom. If you put the TV in 4:3 aspect, it looks normal...like a widescreen movie on a regular TV. Why is the widescreen messed up?
I own several movies, but probably none as old as this. I've never had this problem with any movie I have rented. If I put the TV in 16:9 Zoom, it looks somewhat decent but more of a zoomed in look...lines are not as crisp. Is there some setting I can change to get this to play normally on my TV? Normal meaning widescreen with a less squished effect.
