Help with Brady Bunch Skipping Problem
Discussion in 'TV on DVD and Blu-ray' started by JonathanBB, Mar 17, 2006.
  1. JonathanBB
    JonathanBB Stunt Coordinator
    Jan 1, 2006
    82
    Hi,
    I have recently been watching "The Brady Bunch: The Complete First Season", and I put Disc 2 in for the first time and I am having horrible trouble with the episode "The Voice of Christmas". It keeps skipping, I have already cleaned it twice. Anybody have any suggestions? I bought it back in November so I'm not sure If I can return the set.
    Jonathan
  2. Jack Platt
    Jack Platt Stunt Coordinator
    Sep 17, 2005
    170
    Hi Jonathan,
    I hear you about not being able to go through a disk for several months, than after the 30 day return policy expires or whatever, you're stuck with a bad disk. Unfortunately, you are right about that it might be too late to return the set. If cleaning the disk doesn't work after several tries and playbacks it is most likely that you have a defective disk. You would need to buy another disk......sorry!
    Jack
  3. Mark Talmadge
    Mark Talmadge Cinematographer
    Jul 21, 2005
    2,379
    Try contacting Paramount. You might be able to get a replacement disk without sending in a receipt. I didn't have any trouble with my set.[​IMG]
  4. RandallV
    RandallV Second Unit
    Apr 6, 2005
    299
    I agree with Mark. You should contact Paramount. They have great customer service and I bet they'll send you a replacement disc.
    Good luck.
  5. Ethan Riley
    Ethan Riley Producer
    Oct 12, 2005
    3,612
    370
    4,110
    Does the same hold true for Sony? I have trouble with a Jeffersons disk that I bought over a year ago. Didn't get around to watching it for a long time and now oh well. I'm stuck with it I guess??
  6. RandallV
    Apr 6, 2005
    299
    Ethan,
    Never take that attitude - you should contact Sony customer service. You will probably find a link on The Digital Bits website. Whether you phone or write, I bet they (Sony) will help you.
    Good luck.
  7. Bill>Moore
    Bill>Moore Second Unit
    Mar 28, 2003
    366
    I never have had any problems with my Brady Bunch sets. Definitely contact the studio and ask for a replacement. If that doesn't work, wait around until right after Christmas and do a straight up exchange based on the bad disc. The post-Christmas returns are usually pretty liberal and don't require a receipt for a straight-up exchange.
  8. Justin_M
    Justin_M Agent
    Jun 13, 2001
    48
    JonathanBB and Ethan Riley,
    Have either of you tried the disc on a different DVD player? You can't call it a bad disc unless you know for sure. What is the make and model of your player(s)?
    Try unplugging the power cord for about 30 minutes and then try the disc again. Try the disc on a friend's player to see if the same thing happens. If the disc is truly bad, it will do the same thing on every player. If it works fine on a different player, then you can't totally blame the disc.
    OXonce
  9. JonathanBB
    Jan 1, 2006
    82
    I'll try the disc on another player. Thanks for the advice.
