Steve Morgan
I have 2 subs a PB2 and a Von SChweikert S/3. The PB2 is connected to in/output 1 and the S/3 is connected to in/output 2. Which is the Left channel and which is the right. Is the SVS connected to input/output 1 the left or the right? How do I get both the left engine and the right engine active at the same time without being in the couple mode? I need to cut the SVS by 12 db's at 40hz and the S/3 I need to cut 10db's at the same frequency. Thanks for your help.
Steve
Steve
