Help with Adobe Acrobat Reader Forms
Discussion in 'Computers' started by Darren Crouse, Nov 23, 2003.
  1. Darren Crouse
    Darren Crouse Stunt Coordinator
    Apr 10, 1999
    81
    My wife is applying for her Bachelor of Education this year and the forms are in .pdf files. She would like to find a way to type her responses into the respective boxes as she doesn't have the neatest pen(wo)manship around. Can this be done on the free Acrobe reader at all or are there programs that can allow one to fill the lines in through a word processor?
    Any answers would be both appreciated and insightful,
    Darren Crouse.
  2. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    You can't edit PDFs with the free Acrobat reader. There are programs that will let you though. I google'd "adobe edit" and found a few including this
  3. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    973
    3
    110
    There are some fill-in PDF forms (the IRS has them for instance). You can fill in the blanks and print the result. You can't save the result as a file but you can print it. This capability is determined by the PDF form supplied not necessarily the reader (I use Acrobat 5 right now although 6 is out). Trial and error would be the quickest way to check on the forms you have.
  4. Seth--L
    Seth--L Screenwriter
    Jun 22, 2003
    1,344
    I have the full version which allows you to place text boxes onto documents - I use this functoin to do what you want to do all the time. The free version may have it.
    You can save the changes, only if you first save the file to your hard drive (I did this with college applications).
  5. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    714
    110
    SF Bay Area
    Christian Behrens
  6. Seth--L
    Jun 22, 2003
    1,344
    Read-only may be selected under document properties, attributes.
