help with Adcom 555 amp fuse (1 Viewer)
jinW
Grip
I found one of the 4 fuses in the box was burned. I figured out that it was 6A 125V rated. But I do not konw if it is a fast acting or slow acting type. Could any one help me? Another question is can I use 6A 250V rated fuse instead? I could not find a 125V one at RadioShack. Thanks!
jinW
Grip
I did some research on the net, I think it should be slow acting type. I checked the blown one, there was a 'SA' on it. About the voltage rating, 250V probably will be OK.
Could any one confirm the information for me? Thanks!
jinW
Grip
:) they confirmed my guess...
From Adcom:
It is a slow blow fuse. You can use the 250v, as long as it is a 6amp.
daxlakin
