Help with 8" drivers
Discussion in 'Archived Threads 2001-2004' started by Nathan J, Feb 9, 2003.
  1. Nathan J
    Nathan J Stunt Coordinator
    Mar 24, 2002
    234
    OK, first off, I have an older set of Phase Technology speakers, but I need to replace the 8" woofers in them...one is completely blown, and the other one has all the foam ripped away from the frame, so its on its way out.
    I love the tweeter on them, and I did'nt really want to get rid of them, so I asked how much it would be to get the drivers replaced,....A recone is like $45, and a new woofer is $90. So I was thinking that maybe I would be better off ordering a set of drivers from Madisound or PE, maybe Scan-Speak, or Peerless, or something.
    Anyways, If anyone has any ideas, let me know, I would really appreciate it.
    Nate
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    You have 2 choices, recone/replace with the stock woofers. Or replace with different woofers and as a result build a complelely new crossover.
    The drivers and the XO are a 'system' each related to the other. You can't change one without changing the other
  3. Nathan J
    Mar 24, 2002
    234
    OK, thanks for the help...Maybe I will just get a Phase Tech replacement driver.
    I thought that maybe there would be some other woofer that would work just as well, but I really dont have the time or the space right now to get into a crossover project. [​IMG]
