AnitaPeterson
- Nov 4, 2001
Hi,
As some of you may remember, I bought a few days ago a used LD player. Today, i discovered a very weird problem with it.
It won't play certain discs - when inserted, the player display shows "no disc".
I first thought that it's a question of mastering (i.e. not playing LDs from a certain manufacturer.) However, that was not the case. It will play some Image discs, but not others. It will play some CBF/FOX, or Warner discs, but not others. It will play my Embassy Pictures edition of "Blade Runner", but not the Criterion laserdisc.
However, on the other hand, the reading is stable. In other words, if it can see one LD, it will keep seeing that LD every time I insert it, even after trying (unsuccessfully) to play other discs.
What can be causing this?
I must confess I'm baffled.
Could it be a dirty sensor?
Could it be something more serious?
At this point, the player sees about half of my LDs (I tried them all!) and won't recognize the rest.
Are there any torture tests that would be useful in determining what's wrong with it?
Buying the machine was a bit of agamble, since I only paid CDN $50 on it, but I can't take it back to the shop.
So any suggestion you might have is more than welcome. I'm not squeamish about opening the case, if needed, although I'd rather not go through elaborate soldering or God knows what.
If you can help, please do so.
