Kevin Webb
- Aug 3, 2001
I wanted to get some opinions on the best way to upgrade my CD/music portion of my system.
Budget is around $300
Current setup:
Yamaha RX-630
Panasonic RA60 (got one of the few in existence)
Front Speakers: Wharfdale Rubience RB-25
Rear Speakers: JBL SCS125
The Panasonic is a DVD/DVD-Audio player that sounds nice, but I think I can boost the performance of my CD's.
Am I better served looking at getting a dedicated CD player? Preference is quality over capacity so I have been looking at everything from a NAD 521i to a Sony CA70ES.
Or would I get improvement from upgrading the cables. I'm using the basic Accoustic Research cables, which I think are as good as the entry level Monsters for half the price.
What's the best route? If I had to place a priority, it would be quality, specifically improved detail.
Kevin
Current setup:
Yamaha RX-630
Kevin
