Help w/ a Toshiba Projection TV
Discussion in 'Archived Threads 2001-2004' started by David.Flip, Aug 16, 2002.
  1. David.Flip
    David.Flip Auditioning
    Aug 15, 2002
    2
    Good afternoon:
    I own a Toshiba Projection TV, model # 50G90. I bought
    it "used" about 8 months ago. I suspect the model was
    "new" in 1997.
    The power indicator light on the TV's front panel has
    suddenly begun to flash. The TV will not operate either.
    Nothing happens when I press the power button on the TV
    or the remote control.
    I cannot find any reference to a flashing power indicator
    in the TV's owner's manual. Can any forum members help
    with a diagnosis and corrective steps?
    Thank you,
    David
  2. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    Leave it unplug for a couple of minutes and then plug it back and try it.
  3. David.Flip
    Aug 15, 2002
    2
    Hi Juan,
    Thanks for responding. I tried your suggestion yesterday. I let the TV sit unplugged for about 2 hours. After putting the plug in the electrical socket and pushing the power button the set operated normally for about 5 minutes; then the screen went dark and the power indicator began to flash. The power indicator is still flashing. I will try your suggestion again to see what happens.
    David
  4. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    Sadly, I'd guess that something has gone wrong to trip a safety shutdown. There's probably nothing you personally can do except to call a repairman.
    Jan
