Help, used wrong memorex true 8x firmware!
Discussion in 'Computers' started by Kevin M, Apr 29, 2005.
  1. Kevin M
    Kevin M Producer
    Feb 23, 2000
    5,172
    2
    I tried updating my Memorex True 8x DVD burner's firmware but accidently used the firmware for True 8xn, now the drive won't play, burn or even recognize cd-r's or cd-roms! I have tried flashing it with the correct firmware but the program says available target not found. Is there a way to do this or am I screwed?
  2. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    sorry, as far as i know you are screwed.
    in my experience, if you use the wrong firmware with a drive and it malfunctions it is probably toast. that is why there are a number of warnings about flashing drives that pop up before you complete the flash.
  3. Kevin M
    Kevin M Producer
    Feb 23, 2000
    5,172
    2
    Yes, I know that there are warnings but accidents happen, plus no such pop-up popped up.
    And it isn't exactly toast, it still plays and burns DVD's and plays standard audio cd's, it just hangs up on cd-roms and cd-r's.
    Anyone else have some advice?
  4. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    contact the manufacturer, if anyone has an answer it'd be them right.
    let us know either way, i'm curious
  5. DanielM
    DanielM Stunt Coordinator
    Jul 5, 2002
    224
