HELP!!! Trying to connect PC to Samsung plasma (1 Viewer)
ericepk
Eric
Hi all:
I was wondering if anyone could provide a solution for the following problem?
I am trying to connect my laptop (Thinkpad X60s running XP) via a VGA cable to my Samsung plasma (Model PN50A450). I've set everything up, but for some reason the when I switch the TV source to "PC Input" everything has a tint of PINK.
I've tried EVERYTHING on the TV - adjusting the RGB colors (under white settings), contrast, brightness, changing the TV picture modes (dynamic, standard, gaming, cool1, cool2, etc etc), and everything I can think of under the sun. But NOTHING WORKS!
For some reason the Xbox 360 and HD Cable inputs work perfectly, and it's just the PC input which has this "pink/red" problem...
I would GREATLY appreciate ANY help!!!!
Thank you
shawtyten
Jason
It could just be a loose connection. However, it may be a bad connection if you've made sure your connections are tight.
Chast02
