Help! Too Much Projector Fan Noise
Discussion in 'Home Theater Projects' started by henry_mundt, Mar 8, 2004.
  1. henry_mundt
    henry_mundt Auditioning
    Mar 7, 2004
    I have just completed my theater and have a Screenplay projector hanging from the ceiling over my seating. It is great, but during quiet parts of movies, the fan noise is distracting. I need advice on building a somewhat soundproof enclosure realizing I will have to vent the projector to keep it cool. What materials work best? Any plans or prefab enclosures on the market?
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Search for hushbox on the various projection forums at AVS. basically you want an enclosure around your projector with sufficient airflow venting out of the box, and often line the box in some acoustical foam or something to help, it can make a big difference. If you want it completely sealed, you can get glass for the front, and have air input and output. It should be relatively easy for you to build a small hushbox for your digital projector
    Here is one of many ideas, this was just one for a CRT that I had a quick link to. Run some searches you'll get tons of ideas.
  3. ChrisWiggles
    Aug 19, 2002
    4,791
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
