Help Subwoofer hook up?
Discussion in 'Speakers & Subwoofers' started by PeterST, Jan 17, 2006.
  1. PeterST
    PeterST Auditioning
    Jan 7, 2006
    10
    I need some help, My subwoofer (SoundDynamics THS-12) Has a left and right rca input hook-up but my receiver (Pioneer Elite VSX-27TX) only has 1 RCA output. What do I do in a situation like that? My Sub is older than my receiver.
  2. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    Use a "Y adaptor".
  3. Orlando
    Orlando Stunt Coordinator
    Aug 1, 2000
    208
    I've always had the same answer.
    But my question is, does it matter if you actually run two cables with the y being at the source or only running one wire and splitting it at the sub end?
  4. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    They should be one in the same with no difference. Unless one one the two cables is defective and not carrying the signal correctly.
  5. Doug_
    Doug_ Stunt Coordinator
    Nov 7, 2005
    53
    You can simply hook up one wire to the sub. If you use a Y-adaptor, it will slightly increase the strength of the signal going into the sub. Therefore, it will also slightly increase the gain. It will work either way though.
  6. PeterST
    PeterST Auditioning
    Jan 7, 2006
    10
    Everyone,
    It shure helps ,I really appreciate it.........
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    I use a "Y"... Supposed to be fine with one, but I have always used a "Y" and probably always will. [​IMG]
  8. MikeLi
    MikeLi Supporting Actor
    May 6, 2003
    945
    You can also just plug it into the left incomming and turn up the gain a bit on the sub and get the same thing. All your doing by using the Y is feeding the same info to your sub twice which makes it a bit louder. Again you can acomplish the same thing by turning the gain up on your sub. Some people think because it plays a bit louder on a lower volume they are gaining something somewhere but thats not the case at all...
  9. JeremyErwin
    Feb 11, 2001
    3,218
    2
    I've heard that the Y-adaptor is useful if the subwoofer has a standby mode-- a stronger signal may serve to more quickly activate it.
  10. Rob.melone
    Rob.melone Stunt Coordinator
    Feb 20, 2003
    91
    Peter,
    What does your manual say? That is your best starting point.
    Rob
