Brian Beecher
- Mar 11, 2003
Hi. I was listening to some music today that usually has a good amount of bass but my subwoofer didn't seem to be working. I put in a DVD which I knew had a lot of bass and there was only a little bit of sound coming from the sub, like if the volume was turned down to almost nothing. I checked all of the settings on the woofer and also on the receiver and don't see anything wrong. If I unplug the sub from either the receiver or the woofer itself and just go to plug it back in the subwoofer outputs a ton of bass. The subwoofer is a Klipsch ksw-15 and the receiver is a Yamaha RX-V793 and they've been hooked up for less than 3 years. I don't know if it is a problem with the subwoofer, the receiver or the rca wire that connects them. It just seems like the sub isn't getting the full signal since it is on but with almost no volume. Any suggestions on what could be my problem are greatly appreciated. I can't afford a whole new setup right now, so hopefully it is something I can figure out. Thanks again!!
Brian B
Brian B
