Help selecting 2-3k front projector?
Discussion in 'Displays' started by Brian Holt, Feb 25, 2004.
  1. Brian Holt
    Brian Holt Auditioning
    Feb 25, 2004
    7
    Im finishing my basement with a theater. Will be a windowless part of the room. 17 ft wide, 20 ft deep, 9 ft ceilings. Can I get some input on good front projectors for about 100 inch screens. I plan to build my screen following the advice on this site. Im a newbie to the HT thing, so keep the tech speek low!
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Best bet is to go to projectorcentral.com.
    Some in that range would be the Sanyo Z2/Sony HS20/Panny 500.
    Depends if you want a long/short throw projector.
  3. Brian Holt
    Feb 25, 2004
    7
    I have read the reviews on projectorcentral. They are helpful. I dont see anything about throw distance. I think the answer to your question is im flexible with the throw distance. I will be mounting it to the ceiling, and space isnt an issue. If my mounting area is flexible, does throw distance come into play?
    When reading the reviews- how do I decide if a 3-4k projector is better than a 2-3k projector? Do you just assume the price points dictate better quality? If I can order a proj the classify in the 3-4k range(sony hs20) for under 3k, assume its a good deal? It seems that many like this projector, so Im leaning this way.
