Eric Stuckey
- Mar 24, 1999
- Eric Stuckey
I just got this new digital camcorder and spent the xtra $60 bucks on a firewire port and cable .My problem is I cant figure out ( and the manuel is NO HELP at all ) how to capture it and record to DVD. It has the firewire output on the camara but as far as I can tell the software disk that came with it is only for USB .Has anyone used the firewire cable to capture and then burn to dvd?If so HOW???
Eric
Samsung DV SCD103
Eric
Samsung DV SCD103
