Help required with Home Cinema......
Discussion in 'Displays' started by AndyGas, Jul 27, 2005.
  1. AndyGas
    AndyGas Extra
    Jul 16, 2004
    17
    Have just upgraded my Projector to an NEC MT1030+ which is significantly brighter than the Litepro 580 I was originally using. The picture quality is also miles better but what I've noticed is that dark scenes are a lot more greyer now (which is probably to be expected with a brighter lamp).
    Anyway, will a grey screen help make things look blacker? If so, is there anything I can get to coat my white screen to make it grey? I don't really want the expense of buying another screen because I can't afford one, and besides, I've encased the screen so would have a problem replacing it.
    Also, I'm using a scart control box to connect my DVD/Playstation 2 & Sky Digibox to my TV. The box has three inputs and three outputs - a scart out and two sets of phono connectors but you are only supposed to use one or the other and not both. When I connect my projector via one of the phono connectors, the projected picture looks 'bleached' unless I remove the scart from the TV. Obviously, I don't want to be doing this every time I use my projector so does anyone have any suggestions as to how to overcome this? Perhaps, someone can point me in the right direction of a scart control box that allows you to use multiple outputs with no loss of signal/contrast or one which allows you to switch between the various outputs as well as the inputs.
    TIA. [​IMG]
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I'm going to move your post over to the Display Devices area where more of the projector people hang out.
