help! remote power on/off for yamaha C920?
Discussion in 'Archived Threads 2001-2004' started by Naddy, Mar 16, 2003.
  1. Naddy
    Naddy Extra
    Jan 17, 2003
    24
    Hi all,
    For those that have the Yamaha DVD-C920 changer or equivalent, is there a way to power the changer on and off remotely by programming a learning remote?
    thanks!
  2. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    if it doesn't have a standby feature, then plug into back of amp if possible.
  3. Phil*K
    Phil*K Stunt Coordinator
    Jan 23, 2003
    170
    There is no way to use the remote for this. I just plugged mine into the back of the receiver.
    Phil
  4. Naddy
    Naddy Extra
    Jan 17, 2003
    24
    Hi guys,
    Thanks for the replys, however, I'm not sure what you mean by plugging into the back of the receiver?
    /Naddy
  5. Phil*K
    Jan 23, 2003
    170
    You should have outlets on the back of your receiver. What I did was plug mine into one of those and had the DVD player turn off and on with the receiver.
    Phil
