Marty Carry
Grip
- Mar 11, 2003
I have a Yamaha Lpx-500 projector that is over 4 years old. It does not have a hdmi input but it does have component and dvi inputs. The projector states it can accept a 1080p signal through RGB only. In today's hdmi world does that translate into...1. I am screwed with this projector to receive a 1080p signal or 2. do I need to buy another type of cable. I really am only looking to hook it up to my new sony $499 blue ray player (you know which one that is, right?). I believe that player states it can only output 1080p with a hdmi cable.
For some reason I have not been able to get the dvi connection to work for this projector and I have tried an hdmi to dvi cable already to no avail. Seeing that the bluray player outputs only through hdmi, I guess I am asking if an hdmi to RGB cable exists and does an RGB cable simply connect to your component inputs? HELP! and thanks....marty.
