Help please
Discussion in 'Beginners, General Questions' started by ben.s-s, Mar 9, 2004.
  1. ben.s-s
    ben.s-s Auditioning
    Mar 8, 2004
    I just bought a marantz sr4300 and at the moment dont have enough speakers, so i was wondering if it was possible to make my TV the centre speaker. Any help would be greatly appreciated.
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    This is a popular solution- however on most receivers it might be difficult.
    You would need a preamp output on the receiver for center channel (you cannot just hook the speaker output from the receiver to the TV- because this output is POWERED it wil fry something).
    I actually did this for a while with my first setup (an old Pioneer that has a preamp output for the center)-- and had tons of problems. First of all, the output from the preamp out was relatively low level- meaning the TV had to be CRANKED really loud for it to work right- and so on cable TV with bad white signal- the white level would crosstalk into the audio, and emit a really crappy BUZZ...
    In addition, it sounded HORRIBLE. I found that using my receiver in "phanotm" mode (which was what they used to call it if you had no center channel- now you just tell the receiver you ahve none)--- I found doing this made the l/r speakers get the center signal, and it sounded 100 fold better.
    I don't know your sr 4300 specifically- but if it has preamp outputs for the channels, you could wire the center output into the TV's line input (make sure to get a Y adapter from radio shack because the receiver will only have 1 center output, and you'll need to plug it into the L & R channel inputs on the TV)-- if you have the jacks on the receiver, if you buy the adapter- you could then try it out, and probably find you like it better with the main speakers doing the job.
    YMMV
    Vince
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    What vine said, but don't waste your time, tv speakers suck. unless your other speakers are unbeleiveably bad, go without a center for the time being. Just make sure you go into the menus and set your center to OFF, or you'll lose that channel since the receiver will think theres a center connected if it's set to ON.
  4. Kerryn R
    Kerryn R Auditioning
    Feb 11, 2004
    12
    aw - I don't know if all TV speakers suck - my Loewe set can hold it's head up in that regard. I use both the HT system and the tv in tandem - I find it provides depth and richness to the overall soundscape. Is that a bad thing to do?
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    It's "bad" if it's giving you inaccurate sound. But if you like what you're hearing, who else do you have to please?
  6. Clayton Jr
    Clayton Jr Extra
    Jan 13, 2004
    17
    Certain televisions (like my Toshiba 34HFX83) have a switch that lets you specifically designate the TV's speakers to be the center channel. Since the HFX83 has excellent speakers and a built-in subwoofer, this isn't a bad solution.
  7. Cory_W
    Cory_W Auditioning
    Feb 27, 2004
    3
    It really does not matter how good someone thinks their TV speakers are, the fact is they are all poor quality compaired to a seperate center channel speaker. Its just better to cough up the extra cash.
  8. DanielKellmii
    DanielKellmii Supporting Actor
    Feb 5, 2004
    524
    Go to Goodwill or a garage sale and plunk down five bucks. It will be better than your TV speakers and won't be so complicated.
