Help Please - Small LCD for kitchen?
Discussion in 'Displays' started by Mike Marino, May 16, 2005.
  1. Mike Marino
    Mike Marino Auditioning
    Jan 4, 2000
    8
    I'm looking for a small (15" - 17") TV for the kitchen and the wife has decreed that a flat panel is in order. The set will be used exclusively for direct-to-set (no cable box) TV viewing, so HD-capable isn't required (or is it?). Should I go 16x9 or stay with 4x3? I've heard also LCDs look terrible displaying standard TV signals - true or false? I was considering a new Sony 17" HD-capable display (MFM-HT75W) but can't find anyplace in my area to see one - does anyone have experience with this set? Any help sorting this out is much appreciated!
    Thanks, Mike
  2. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    The small standard def Sharp Aquos sets look pretty darn good with SD content. I installed two in a friend's home recently (one 15" on an articulating mount in a bathroom) and one 17" on flip down and swivel mount under a kitchen cabinet, both 4:3)...both are fed a direct cable line with no STB and both have very nice picture. Just be aware that a decent mount will cost $100+, so add that to your budget. I also have to imagine that most of the small LCDs come with a standard VESA mount points but being that Sony seems to march to their own beat you might want to make sure whatever you decide to buy isn't limited to a proprietary mounting system that will limit your mount options or drive cost up unnecessarily.
  3. Tyson Wetzel
    Tyson Wetzel Stunt Coordinator
    Jul 1, 2004
    112
    LG's 15" wireless is pretty cool. I like the fact that you can take it everywhere.
  4. Mike Marino
    Jan 4, 2000
    8
    Thanks for the recommendations. I hadn't thought of the wireless option - I'll definitely check that out since it doesn't require cutting the tile in my backsplash!
