Paul Gere
- Sep 3, 1999
Guys,
Forgive my ignorance, but need some help...
I had been using a Xantech AC-1 to switch power on for my two amps and it recently freaked out on me, so I've replaced it with a Niles AC-3, as it offers two switched outlets (I had to split the singe outlet from the AC-1).
Question is, the Niles AC-3 spec says 1500w max load, all 3 outlets. Not sure what that means or if i should be concerned about the "load" my amps will give it.
The amps:
Parasound HCA-2200II (250w x2)
Parasound HCA2205AT (220w x 5)
Where I'm confused is that when I go to the specs section for these amps on the Parasound site, it says power consumption for the 2205 is 1500w and the 2200 is 1000 watts (a combined wattage of 2,500)
Should I be concerned by this? Should I NOT power these with the Niles? Should I be using two AC-3s (1 for each amp?) Not sure if I should be worried or not, since the AC-1 seemed to hold up for almost 10 years with the same load.... Is the "spec" wattage on the amps peak or continuous? Does that matter?!
Could some kind soul please help me sort this out??!!
Link to niles AC-3 info:
http://www.nilesaudio.com/product.php?prodID=AC-3&recordID=120Volt%20AC%20Power%20Switching%20Systems&categoryID=Switching%20Systems&catcdID=10&prdcdID=FG00242
Link to Parasound 2205AT specs (2200II specs also posted at this site)
http://www.parasound.com/vintage/hca2205at.php
THANK YOU to all who are more knowledgeable than I am on this sort of thing!!
The amps:
