Help picking a sub
Discussion in 'Archived Threads 2001-2004' started by Tim Reimler, Apr 4, 2002.
  1. Tim Reimler
    Tim Reimler Auditioning
    Apr 3, 2002
    3
    Hello, I was directed here from a member of DSLReports so here I am. I want to get an OK sub without spending a ton of $$$, under 200. Here is what I got
    15 x 12 room ina a basment w/ drop cellings and carpet
    A Sony Digital ready reciever
    Plain Jane Phillips DVD player
    DD decoder
    CD changer
    My compter w/Sound Blaster Live! 5.1
    2 JBL surround speaker
    A JBL center channel
    And 2 unknow boxed speakers w/ a tweater, mid, and a woffer each.
    Since it was asked before I will be playing just about everything DVDs CDs and games on my PC. So with all that said what would be an OK sub if not alot of $$$. Thanks
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
  3. BruZZi
    BruZZi Second Unit
    Nov 1, 1999
    327
  4. Tim Reimler
    Apr 3, 2002
    3
    Thanks for the suggestion. I'll look into it.
  5. Cave Canem
    Cave Canem Auditioning
    Mar 8, 2002
    14
    I have the afore mentioned Sony. Great woofer, plenty of base. I got mine for $189 at best buy, im sure they are cheaper elsewhere.
    I believe Aiwa has a 10" 150w for around $150 at circuit city. I went with the sony b/c thats what my whole system is.
    When you buy the woofer, do not be taken in by the "YOU NEED THE $40 MONSTER WOOFER CABLE TO GET THE BEST BASE". Go to radio shack and get the gold series, sounds just as good and is about $28 cheaper. I know this from experience. [​IMG]
  6. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Take a look to the Audiosource SW Fifteen, it can be found around the net for about the same that the Sony, but its better. It have 5Hz more extension (25Hz vs 30Hz on the Sony) and it have more power (250 watts RMS).
  7. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,213
    I'd go with the SA-WM40 and get an older used SVS driver for it. Should sound much better then.
  8. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    If you think you could handle building a box and cutting some circles (ie you have or can borrow the tools and basic know how) consider heading over to the DIY/Advanced section and asking about building your own.
    You would be amazed at what is possible with $200-$250. At $200 you won't have much money left for finish, so it might not look that great until you can afford to put a finish on it, but it will be leaps and bounds above what you can get commercially for $200 (if done right you could expect to get close to or match SVS 20-39PCi performance).
  9. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    Tim,
    If you get the Sony, search for the posts talking about "stuffing" the sub. $5 of polyester fiberfill will improve the sound of the Sony...
  10. David King
    David King Stunt Coordinator
    Mar 2, 2002
    141
    I have the Sony and the pollyfill is a requirement. The sub is very boomy out of the box, but add a little polly and the sub is very very respectable. I have not heard all
  11. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    The Sony enclosure will be too small, the port will be to narrow, and the port will tune the enclosure too high for the SVS driver.
  12. Tim Reimler
    Apr 3, 2002
    3
    Thanks guys. I'll give your suggestions a good looking over. What do you think about KLH?
  13. Justin Bowser
    Apr 1, 2002
    28
    I just received my JBL PB10 yesterday and I'm impressed! I could "feel" it at the other end of the house with SW Episode I going...
