HELP: Panamax Max 5100: UNSAFE VOLTAGE???
Discussion in 'Home Theater Projects' started by tonyGar, May 17, 2006.
  1. tonyGar
    tonyGar Agent
    Jan 2, 2006
    35
    I have a HT with a Panamax Max 5100 and twice in the last 4 months has had the red light "Unsafe Voltage" go off and my system no longer has electricity. The last time the next morning it was up again.
    Does anyone have familiarity with this unit? What it does? What "Unsafe Voltage" mean and what I should do in light of this light going off?
    Thank you
    Tony
  2. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    Sounds like the Panamax is using the Surgegate Plus Protection feature. If the Max 5100 senses an unsafe power condition it will automatically disconnect your equipment from the power to protect equipment from damage. Unsafe voltage LED is acivated and will blink once every 2 seconds during the unsafe voltage condition. The Max 5100 requires line voltage to return to within the safe operating range for 10 seconds before returning to normal operating mode.
    Bottom line sounds like Max is doing its job and you may have a voltage problem.
