Help Needed With CGI asap!!
Discussion in 'Computers' started by Chuck C, Apr 24, 2003.
  1. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    Dear fellow HTF computer gurus,
    I am in a web design class and I am trying to create a form that submits your name, email, and message to a certain location (my email). here's what it looks like without the CGI and minus descriptions:
    http://unixgen.muohio.edu/~corsilcj/tcontact.html
    How can I get this thing to work...I'd like it to display a "your message has been sent" window as well.
    thanks!!
  2. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,254
    1,641
    9,110
    One Loudoun, Ashburn, VA
    David Fischer
    Chuck - I've got PHP code that does this. I can send it to you if you want.
    I use it for my feedback form. You type in your name, etc and it it emails me the message. It also displays a "Mail sent" message after you submit it.
  3. MikeAlletto
    MikeAlletto Cinematographer
    Mar 11, 2000
    2,369
    Thats a pretty basic beginner project. Search online for web forms and perl or php code. I never had a class but just had to do it for something quick at work. It was pretty easy to find references online that'll give you a sample. Once you learn how to interact with one text field and do something with the submmitted data everything else works basically the same.
    Its a lot more rewarding when you figure it out since you are still in class instead of just getting someone to give you the code [​IMG]
