rockblock
- Jan 10, 2009
- Rock
Hi Folks, I'm quite new to this, so any help would be greatly appreciated.
I just got a pair of used Sony tower speakers SS-AV55 (130W) that each have 2 woofers (6" each)+ 1" dome tweeter.
The problem is that I think tweeters are busted, as only the woofers can be heard. I took out the tweeters and checked them each individually...they produce barely any sound...with my ear against them and slowly turning up the volume, I can barely hear anything...upon taking the tweeter out, through the hole I can see that internally, all 3 drivers feed into some sort of circuit board with capacitors & coils (I guess it's the crossover board). On the other side of the board are the 2 speaker connections.
The tweeter has no specs on them, just some numbers stamped on the magnet. The only specs that I see are on the back of the cabinets:
SONY MODEL SS-AV55
SPEAKER SYSTEM
RATED IMPEDANCE: 8 ohms
MAX INPUT POWER: 130W (non-clipped)
So, does this mean that each of the 3 drivers drivers has an impedance of 8 ohms? Same for power: does the 130W mean that each driver can handle 130W, or is that the combined power? How do I know what wattage I should be looking at for when choosing a suitable tweeter (I've seen them go from 25W->100W).
It's interesting how both tweeters react the same way...
Any help would be greatly appreciated.
SONY MODEL SS-AV55
SPEAKER SYSTEM
