Help needed, screen size
Discussion in 'Home Theater Projects' started by Jim Mcc, Apr 28, 2004.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I am ready to build my first screen out of blackout cloth, and I need some advice on screen size. It appears I can't go taller than 52" due to amount of stretch on this 54" material. However, I can go at least 96" wide on my wall. I know 16:9 size is 52"X92". My question is should I Make screen wider than 92" or leave it at 92"? Thanks, I want to build it tomorrow.
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    52x92 worked out just fine for my screen.
  3. DanielGM
    DanielGM Stunt Coordinator
    Jul 15, 2003
    116
    While 16:9 is the "widescreen" resolution. Most movies I have seen are in 1.85:1 (not 1.77:1) So you could try going with 96.2x52 if you wanted. Make sure you pick up some masking material though for HDTV and the occasional 1.77:1 movie
