Dave Mack
- Jan 28, 2002
Ok, here's the deal...
I just got a new modified (Region-free) JVC XV-NA70BK the other day to upgrade from an older 600, (also region free...) The 600 had certain issues, the subtitle bug, a REALLY bad Video mode, MUCH worse than the mode on my previous JVC SA70, and had a tendency for the pic. to jump whenever there was a bright flash on the screen, like in the flashback scnes in The Crow...
Well, 1st... The PQ on the new NA70 looked amazing. Apparently the 12 bit D/A convereter looks better then the 10 bit on the earlier models.
2nd, No subtitle bug.
3rd, no pic. jumping during flashing scenes...
4th, an additional VIDEO mode called ACTIVE which is MUCH better than the 600's, about on par with the old SA70's still not great but watchable...
5th, A 1.8X zoom which scales non annie WS material perfectly, (like Titanic...)
Then the bad news... After watching and enjoying the pic. for awhile, I started noticing something... The Pic. would skip. Like a stutter... NOT like the VIDEO mode on the 600, that was more of a double image mess... This was as if you were watching at 15fps. instead of 30. It was Most noticeable on pans of course. And the freaky thing is, it would come and go. If you paused the DVD when occuring, it might stop for awhile but then it could start back up. And this was in FILM mode, with a film based DVD, like American Beauty... This is NOT a "combing" issue.
So I did some searching on the net and discovered that this problem was prevalent in many of the newer models.. the 44, 50 and 55, with many websit and owner reviews noting and complaining about the problem.
Also, the 55 and 70 and 77 have been pulled from sale on Amazon, perhaps JVC realized the problem and are trying to rectify it.
So, anyone know the story? In every other regard, this player is pretty sweet. GREAT PAL-NTSC conversion, 1.8 zoom, windowboxing of 4x3, and the 12 bit DAC looks better than the 10 bit on the 600 and 70. Incredible PQ IMHO...
Is there maybe a firmware fix? Did I just get a lemon and some models are ok? (seemed to be the case re: the 50 over at Amazon reviews...
And if I do have to return it, any reccs. for a 12 bit (after 12, hard to go back to 10 bit...) PAL-NTSC converting player with decent FILM and VIDEO modes, windowboxing and zoom..?
I heard that the Philips 963 is great but has the "angle" bug and can only zoom when pillarboxed...
Or should I just hang onto my old 600 until I am ready to upgrade to a DVI player when my monitor situation changes,...
:frowning: Bummed in NYC....
