Andrey_Sea
- May 16, 2002
Hi,
This is my first post and sorry it is a little long, but I have a lot of questions
I have been reading quite a bit here for the past couple days, but am still really confused about which equipment to buy.
My setup so far:
19 by 13 feet room
Viewing distance is mostly 9-10 feet from the set, but can be as far as 14 feet.
Another restriction is the door which is only 29" and on the second floor, so things like Samsung HCL652WX 65-Inch will not fit through it ( Samsung Dimensions: 59 3/4(W) x 62 1/2(H) x 32(D) ).
My budget is initially set at $3,000, but can stretch a little if there is a really good reason for it. My wife will appreciate it to be closer to $2,200 though, and I don't think she likes the idea of a front projector, too small of a box and not sexy enough for that kind of money.
We are mainly watching DVD disks from Netflix and don't watch any TV really, which may change when there is more HDTV programming available.
So far I like the following TVs:
Sony KP57HW40 57 inch
Toshiba 57HX81 57 inch
Mitsubishi WS-55819 55 inch
Pioneer SD533HD5 53 inch
Other considerations (in order of importance):
Bigger screen is better.
Would like it to last at least 5 or more years.
Picture quality matters.
I like the look of Sony and Pioneer the best.
Additional Questions:
Since I will mostly be watching DVD how critical are features such as component video and progressive scan on a DVD player? Should I upgrade my DVD player since it only has SVHS as its highest quality Video output? If I should upgrade it, then which DVD player would you suggest?
I was thinking of buying the TV at local Magnolia HiFi store and getting a warranty which comes with their setup. Do you think it will be sufficient for a good picture? I like playing around with electronics and computers but would like to avoid opening the tv box, is there anything I can do myself to tweak the set I buy?
My current setup is good in terms of Audio, but is really out of date in terms of video.
Audio:
Receiver - Pioneer D509S
Speakers Front - AR S50s
http://www.acoustic-research.com/s50_content.asp
Center - AR SC2
Rear - AR S20s
Video:
Sony 27"
Panasonic A115 DVD (NO COMPONENT video outputs, only SVHS)
My setup so far:
19 by 13 feet room
Audio:
Center - AR SC2
Rear - AR S20s
Video:
Sony 27"
