Help needed choosing amp!!!
Discussion in 'AV Receivers' started by JohMabe, Jul 28, 2003.
  1. JohMabe
    JohMabe Stunt Coordinator
    Jul 28, 2003
    108
    I am buying a new amplification set for my system, and I now have my options narrowed to basically four:
    Roksan Kandy KA-1 integrated (1100 dollars)
    Adcom 5800 + Rotel RC972 preamp (1000)
    Adcom 7000 integrated (1000)
    Marantz SR-18 receiver (900)
    Considering the closest upgrade I have in mind is a subwoofer, and I will use the amp to drive a pair of JBL S310II, mainly for music usage, what would be the recommendation?
  2. Scott_N
    Scott_N Second Unit
    Jan 22, 2003
    425
    Of the four I would choose the Roksan. I have a SR-18 in my HT system and it has a warm pleasant sound to it but I would still choose a nice integrated like the Roksan over a SR-18 for 2-channel. Have you considered brands like NAD, Arcam and Unison also?
  3. JohMabe
    Jul 28, 2003
    108
    But will the Roksan Kandy deliver more power than the Adcom combo? Or will deliver less, with better quality?
  4. Scott_N
    Scott_N Second Unit
    Jan 22, 2003
    425
    The Roksan does have 110wpc so it has plenty of power. I think the Roksan would provide better detail than the Adcom. The Rotel/Adcom combo would have more slam. All in what you value.
  5. MikeTrotter
    MikeTrotter Agent
    Jul 26, 2003
    28
    For music I would go with the Marantz SR-18.Very musical receiver.
  6. JohMabe
    Jul 28, 2003
    108
    Is the Roksan that good? Or is the Adcom 5800 that crap?
    thanks for the advice you guys
  7. Scott_N
    Scott_N Second Unit
    Jan 22, 2003
    425
    I don't care for Adcom but it's your ears so try and listen to your choices before buying if you can.
  8. DaleBesh
    DaleBesh Stunt Coordinator
    Oct 26, 2002
    163
    I would probably go for B&K or Parasound before Adcom. Just a personal choice.
