Help! Need source for 36+" monitor
Discussion in 'Archived Threads 2001-2004' started by Rob Lloyd, Apr 18, 2002.
  1. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    We need to get a couple 36"+ monitors or TVs. I was getting pricing for renting them and it was $1200+/wk. I'd rather buy them for the same price than pay $4500 for the 2 weeks use.
    Anyone have any ideas of brands and sources? I'm striking out on my usual places of purchase.
    What we need is 1024x768, vga input.
    TIA,
    Rob Lloyd
  2. Jeffrey_Jones
    Jeffrey_Jones Second Unit
    Nov 6, 2001
    283
    I'm not sure about large professional computer monitors but I do know that Sampo and Princeton Graphics both make 27", 32", 34" and I believe 36" HDTV/Monitors. I know the Sampo 34" 34WHD5 will do 1024x768 and it can be had for under 2K right now. You might want to check out Ubid and Buy.com for current prices. After your finished using it as a monitor, you would have a wonderful HDTV to take home with you.
    - Jeff
  3. Rob Lloyd
    Mar 22, 2001
    234
    Thanks. I already checked out buy.com unfortunatly we need them for Tuesday and they are out of stock.
    Seems hard to find these items. Guess they aren't big sellers.
  4. Jeffrey_Jones
    Nov 6, 2001
    283
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Rob,
    Have you considered a small digital projector? THe LT-150 from NEC 1is 1024x768 native, very bright, especially if only 36 inch wide!
    -Vince
