HELP! Need cure for Worm!
Discussion in 'Archived Threads 2001-2004' started by Ushabye, Oct 7, 2002.
  1. Ushabye
    Ushabye Projectionist
    Mar 31, 1999
    176
    32
    Dublin, Ireland.
    Paul
    I have just discovered a worm on my system, but cannot find a solution to removing it. I would be grateful If someone could help me out. It seems to be preventing my Norton anti-virus program from running (shuts it down after 30 secs or so when I try to open it.) It came in an email titled: "A gift" , there's an attatchment: advantages.ppt.exe (49kb) Even when I re-install Norton it still will only remain open for 30secs then shuts down.
    This may be the I. GIFT worm but I'm not sure. Can anybody help?
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Ouch! This morning the news mentioned the 'bugbear' worm. Go to http://www.symantec.com for more info.
    I did hear that you can catch it without even opening it up. I do hope you didn't open it, in any case. Best of luck.
    Glenn
  3. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
    See if you can run an online scan using House Call. Maybe that will run for you and kill your virus. Go to http://www.antivirus.com and look for the free tools area.
  4. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    You can download a Bugbear removal tool from this link on Symantec's website.
    For more information on Bugbear, click here.
    If you do a Ctrl-Alt-Del and kill the worm process, you should be able to run Norton. You'll need to update to the latest definitions.
    Bugbear is spreading faster than Klez spread during its peak earlier in the year, according to various news sites I've read.
  5. Ushabye
    Mar 31, 1999
    176
    32
    Dublin, Ireland.
    Paul
    Thanks Fellas, that did the trick!
  6. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    Just for info, www.pandasoftware.com has a free removal tool that seems to work better than the symantec tool. I've used both (that frigging worm is running amok here at my company).
    Has anyone else had any experience with this? We have a small network set up and this worm (as well as the opaserv worm) have completely fouled up all network settings on our 95/98 machines. NT based are OK, but all network shares have been changed to file servers so the virus can spread over the network. None of this is resolved by only removing and cleaning the virus. Any ideas on how to resolve?
  7. Kevin P
    Jan 18, 1999
    1,439
    Mike, that sounds like something the Opaserv worm might do. Check this text excerpt from Symantec's website:
  8. Mike LS
    Jun 29, 2000
    838
    Yeah, it's definitely the opaserv worm. I've removed it from all affected machines, but still haven't found a fix for the network and print share problem......other than reformat that is.
  9. Kevin P
    Jan 18, 1999
    1,439
    What kind of problem are you having with your file and printer shares? If the worm created shares you can delete them from Explorer easily.
  10. Mike LS
    Jun 29, 2000
    838
    I think I found the problem late yesterday. It seems that the worm was affecting some emulation software that we use here and was creating NFS shares that we couldn't get rid of until the software was uninstalled and reinstalled.
