Travis D
- Feb 15, 2001
Now compared to some of you, I'm a little challenged in the so-called "Money Department." I've decided this will not stop me from getting a worthwhile system. I currently have an AIWA home theater shelf system :ick: and will be upgrading to a Kenwood 507.
The thing is is that I am in desperate need of new speakers and a sub. My current back speakers that came with the AIWA are so bad that it sounds like it is stuck inside a pig's ass it is so muffled. Same goes for the center speaker, in fact so much so that I've told the DD and DTS decoders on my Sony 670 DVD Player to redirect the center channel to the 2 front L&R's so I could get higher fidelity out of people's voices.
I need a good speaker package w/ a sub for around 200 dollars if that is possible. I've come up with these 2 packages so far:
KLH HTA809
and
Audiosource SYSTEM25
Now I'm sure some of you more well informed people out there can give me a helping hand.
Thank you in advance,
Travis
[Edited last by Travis D on September 30, 2001 at 06:14 PM]
KLH HTA809
and
Travis
