Joseph Young
- Oct 30, 2001
I have an Energy S8.2 Sub, recently upgraded from a 50 watt Sony SW. I have had great results from it, much deeper and tighter bass than I am used to. However, during particularly aggressive scenes, the low frequency will literally vibrate my walls, causing a very distracting buzzing noise. This is more due to the small size of the room and the necessity of placing my HT in the corner.
My question is: what is the best way to alleviate this without simply turning down the LFE? Is it a bad idea to place something (such as a phone book) underneath the sub to help 'absorb' the vibration? Because honestly, this really helped, but it doesn't seem like a good long-term solution.
I have a small (10 X 12) room for my HT and very little space in which to maneuver. Any tips & tricks would be appreciated.
Cheers,
Joseph
Cheers,
Joseph
