Paolo DT
- Jan 10, 2005
Hello. I was wondering if someone can shed some light on this problem.
I recently bought the new Panasonic 7-series 50" HD plasma display, and in general I am very happy with it.
However, I also bought a DVI input card in order to connect it, via dvi cable, to my new Denon 2910 dvd player.
Now, everything is fine as long as I set the denon to 480i, but when I change the resolution to either 720p or 1080, the image disappears completely form the screen, and I can't seem to do anything to make it work.
I called Panasonic assistance, and they say that I should not use the DVI input card/cable to view a dvd player but only a computer. According to them, the problem would be solved by buying a HDMI card and connecting that way (which I wish they had told me before I bougth the DVI card...) to the HDMI out of the Denon.
Does this make sense? And if it does, then why would Denon put a DVI output on a dvd player if it can't be used properly?
I hope someone here can help me out.
Thanks in advance,
Paolo
Thanks in advance,
Paolo
