help! my HK AVR320 is going crazy... :(
Discussion in 'AV Receivers' started by Bin_L, Aug 2, 2003.
  1. Bin_L
    Bin_L Auditioning
    Aug 1, 2003
    2
    first off hello all, i'm new here [​IMG]
    My HK AVR320 is having a problem, when turn on it just shuts itself off in like 3 seconds. what can be the problem? I have reset the receiver by pressing the tone & fm mode button and it still does the same. Oh and the other problem is I lost my receipt and probably can't bring it to the service center to be repaired even though its under 1 year....
    Has anybody who owns the avr320 experienced this problem? Thanks
  2. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    Mine works fine but check your speaker connections. Perhaps there's a loose wire touching the chassis or another speaker terminal. Pull them all out, check for loose strands. I'm not sure if you're using banana plugs or bare wire but that's always the first place to check. Or also if you accidentally reversed polarity on either the terminals or at the speaker.
    I just left mine on for 24 hours accidentally. It was still playing the radio.
  3. Bin_L
    Bin_L Auditioning
    Aug 1, 2003
    2
    I've pulled out every connection and wires, does the same thing still...
  4. RobWil
    RobWil Supporting Actor
    Mar 17, 2003
    733
    could just be a faulty switch. maybe you don't need the receipt...could be they have your purchase on record. If you bought it at a place like Circuit City it should be no problem.
