Father John A
- Jul 22, 2002
My Sony DVP-S360 is dying.....I think.
Trying to watch the Incredibles tonight and half way through it started glitching out (freezing, pixelating, skipping, etc). I checked the disc and found it to be perfectly clean. I then tried it on another of the same model and it played fine. Ditto with my Mintek. So my questions are:
- Is it most likely dying? Is there any chance it needs cleaning?
- If I spring for a new one, what should I be looking for in terms of compatiblity down the road (connections, etc.
I plan on getting a new TV withing the next year (I hope) and will most likely go with DLP or LCD RP.
Any advice will be appreciated.
