Lucas Dang
- Apr 5, 2000
I have a mitsubishi 65807 WS HDTV and version 1 DVDO iscan. I bought a VGA to component cable, and I hooked it up. I get a picture thats in the animorphic screen mode, but it wont allow me to switch modes, its the locked in progressive problem, but the thing is my tv is not supposed to lock in progressive. I have Toshiba 5109 ProgScan DVD also hooked up to the component inputs, it doesnt lock, and I can select the modes.
My tv manual says it is compatible with RGB HV sync, Component YPrBr, and even RGB sync on green. It should be working, I tried all the inputs including the one used for the dvd player which works properly, none of them are allowing me to change formats.
Does anyone know whats wrong here, is the dvdo scan not compatible. On top of all this, without being able to compare it in the proper screen format. So far the picture does not look any better than the picture thats line doubled by the tv's internal scanner. I just wasted hundreds of bucks for nothing or what?
Please help, thanks in advance.
