Help? MiniDV via Coax on an inputless TV?
Discussion in 'Archived Threads 2001-2004' started by Greg Silberman, Nov 6, 2001.
  1. Greg Silberman
    Greg Silberman Auditioning
    Nov 13, 1999
    7
    Hello
    A freind just calle dwith an intresing problem. He wants to be able to output the image from a miniDV camera to a television that only has antenna and a coax connection. The TV is only 3 years old but apparently does not even have a composite input.
    I believe it is his parents TV and the suggsion buy a better TV, while accurate, is not very helpful in this situation.
    Is there a composite to coax converter?
    Gregory P. Silberman
    [email protected]
  2. Drew Eckhardt
    Drew Eckhardt Stunt Coordinator
    May 10, 2001
    246
    It's called an RF modulator and is available from your friendly neighborhood Target, Radio Shack, etc. for less than $30. I use one on all my vacations to get video up on the hotel TVs.
    [Edited last by Drew Eckhardt on November 06, 2001 at 06:49 PM]
  3. Todd K
    Todd K Second Unit
    Oct 21, 2001
    477
    How do these things work? If you have the converter going into the RF input on the TV, how can you get a cable television signal? Or is there a switcher on it that allows you to switch back and forth?
    Right now I'm in a situation where I have a television with only an RF input, and a DVD player (from my computer with a TV out card). Until now, the only way I could connect it was through my vcr, except I get distortion from most DVDs' macrovision encoding.
    Todd K.
  4. Drew Eckhardt
    May 10, 2001
    246
    I think the one in my gear bag has a pass-through connection for Antenna/Cable which is active when there's no signal. Otherwise, you can run a $9.95 manual switch box. DVD via RF modulator on one input, VCR on the other.
  5. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    986
    8
    110
    With an RCA to "F" adapter you could also use an old Nintendo RF switch box if you have one lying around.
